Forced induction with high compression
With a static CR of 12.23:1, DCR at 9.01:1 could a turbo or supercharger be done as long as the boost is kept low on the street, alot of timing pulled and a good tune or would it just be a ticking time bomb no matter what even with forged internals?
Re: Forced induction with high compression
No, the bomb wouldn't tick, it would knock.
Couldnt be addressed by pulling alot of timing with less than 8lbs?
with a dynamic ratio at 9:1, you are pushing the limit of pump gas even normally aspirated. I don't see any amount of band-aiding with timing or reducing boost to 8 PSIG that will let the engine live with pump gas.
no, unless you run straight methonal as a fuel
Originally Posted by Honda Hunter
With a static CR of 12.23:1, DCR at 9.01:1 could a turbo or supercharger be done...?
Can you get E85 in your area and are you willing to install a new fuel system? |
New fuel system as in getting a fuel cell etc?
You can run high compression with alcohol, partially because of the octane and partially because it runs so cold. (If I recall correctly, the change of state from liquid to vapor sucks up a LOT of heat. If I am not remembering correctly, hopefully someone will speak up.) Alcohol is normally a PITA to run on the street, but the 15% gasoline content of E85 makes it a lot easier. |
