Finally Got Boost!!!!!!!!!
I just picked a D-1SC and am looking to see what kind of numbers and 1/4 mile times should i see and what have you guys gotten from it also. Here is a basic rundown of my current setup.
Stock long block.
walboro 255 lph fuel pump
Pacesetter long tubes off road y pipe cut out and flowmaster catback
3.73 gears
ls1 aluminum driveshaft
42 lb svo injectors
tune
slp lower control arms
drag radials
Winter build 355 with stock crank scat i beams with 7/16 bolts je forged dish pistons arp on the mains as far as the heads gonna send them to loyd and have him work them over and get a nice cam from him for boost. Alo gonna invest in a 12 bolt or 9 inch. And gonna shoot for some 10 second ets.
I am gonna try my performa built auto with 3000 stall with the stock setup but i am gonna swap a t-56 and spec stage 3+ clutch and flywheel.
Stock long block.
3.73 gears
42 lb svo injectors
tune
drag radials
or at least have the crank cut .010 under and have them radius the edges of the journals, but for a D1SC you will max out the bottom end and the crank still might give out. The scat 7/16 I beams are a goo choice though, theyre lighter than H beams and they rate them to 700 HP.
I have to agree with Jay. Your going to want to use that D-1, and since it's a DD you're going to probably use it a lot. I had a very similar rotating assembly to the 355 you were talking about, and I just pulled it for a fully forged short block. I wish I bought the good stuff first, I would have saved a bunch of cash, especially after paying for the machine shop twice... Just my $.02
