F2 427SBC '69 Camaro
7 Attachment(s)
This build will get me to my goal, or probably a bit quicker. :D The goal has been to run at least 8.50's. The current version of this motor has too much compression for the F2 at almost 14:1. When the Procharger goes on I'll replace the crank with one that has a BBC snout, swap the pistons to bring the compression down and convert to E85. It already has the blower cam in it and the F2 has been sitting in the box next to the car since last summer. Here are the parts involved:
Dart 9.325" deck Iron Eagle block AFR 245 Heads T&D steel body 1.6 ratio 0.550" offset shaft rockers 4/7 Swap solid roller 274/286 @ .050" 0.704" lift Crower Enduramax Lifters Jesel Belt Drive Lunati Promod 6.0" rods JE Pistons Crower crank Dart Manifold Holley 1050 Dominator Attachment 2896 Attachment 2897 Attachment 2898 Attachment 2899 Attachment 2900 Attachment 2901 Attachment 2902 |
Re: F2 427SBC '69 Camaro
3 Attachment(s)
Most of the parts have arrived now but still waiting on pistons and the dampener. I've also decided to go with the Holley Dominator EFI coil on plug set up with Injector Dynamics 2,000cc/min injectors. Injectors and fuel rails are supposed to be in next week so we can modify the intake manifold.
Crower billet rods Attachment 2617 Crower crank Attachment 2618 Motor mocked up with F2 and accessories. Had to replace my electric water pump with a remote electric pump because of the blower belt. Attachment 2619 |
Nice! I have a good friend that built a '62 Nova with an LS2 with a turbo and used that Holley Dominator EFI. That system is awesome--tuning capabilities seem to be endless. I think you will like it. Anxious to see how your project turns out.
4 Attachment(s)
We finally have some pistons! They do look plenty stout.
Attachment 2613 Attachment 2614 Attachment 2615 Attachment 2616 |
3 Attachment(s)
Fuel injection arrived from Holley today. Everything except the injector harness and 2nd O2 sensor harness. Those might arrive next week. Block is machined, cleaned and ready for assembling.
Attachment 2603 Attachment 2604 Attachment 2605 |
2 Attachment(s)
Pre-assembled the shortblock. Rod bolts are are a little close at the bottom of the cylinders so that needs a little grinding. Everything else is fine. The compression ratio came out to 10.1.
Attachment 2601 Attachment 2602 |
7 Attachment(s)
The crankshaft has arrived. Crower did a real nice job balancing it. Now the motor can go together for the final time. :)
Attachment 2587 Attachment 2588 The shortblock is ready to assemble. Would have been done already but we had the wrong main bearings and the right ones were supposed to arrive this morning. Turns out they didn't ship them so they are driving them down from Sacramento. Should be here any time and things can be assembled. :) Attachment 2589 Attachment 2590 Short block is finally together. :) Attachment 2591 Attachment 2592 Attachment 2593 |
12 Attachment(s)
The motor is finally finished and at home. I'll drop it in this weekend and then I need to get busy! I have 2 spare pistons in case I do something stupid. These things are ridiculous!
Attachment 2577 Attachment 2580 Attachment 2583 Attachment 2584 |
Looking good!
4 Attachment(s)
Originally Posted by Purple Poncho
(Post 6993513)
Looking good!
Didn't touch it for the last week since its been close to 110 degrees out. Dropped the motor in today. Slipped in just fine with the blower and accessories on. Attachment 2569 |
Wish it was mine ! Man that looks awesome !
3 Attachment(s)
The serpentine accessory drive finally arrived from Procharger. Now I can run A/C with the F2. Also, the manifold is almost finished. Just need to get it powder coated.
This is a great thread. A shame more people aren’t following it. The forced induction forum used to be fairly active.
This is pretty! Nice work so far!
4 Attachment(s)
The Dominator hat arrived from Steve Morris a couple of weeks ago. And the manifold is finally powder coated. Now I can bolt it on and finish hooking everything up. The car is scheduled to go to BRE Rods and Classics in a couple weeks to finish the EFI so the car will be ready for the dyno.
