D1 external oil source
Currently running a D1 on a 383 97ss. Thinking of fabricating an external oil source (non-engine) to lube the Procharger. Tank + electric Weldon oil pump (3_lbs/ 3 to 5 amp load). I see the Procharger site talks about self_contained oiling as better due to lower temperature operation and possibly reduced charged air temps. Comments??? B.
I think it would be worthwhile for two reasons:
1) Lower intake temps
2) If the blower lets loose you don't contaminate your engine oil
BTW, the Renegade class of the NMRA does not allow the use of intercoolers. I remember reading when LaRocca switched to a self contained unit his IATs dropped by 55 degrees. Now, combine that w/ Alky or an IC, it could proove very beneficial.
Thanks for repley. Was starting to think it was a dumb question (probably is). I have a Weldon #9200 vane type oil pump (picked up used) and it will put out 30 psi minimum -6an line outlet. A very quality pump. I was thinking of fabricating a small tank (from 3" alum tube about 9" long) since I have all the fabrication tools. Don't know about temp data, but, I know the blower involute does get hot. I think I will do this, but, as a side project. Sorry I posted this. B. (97ss 383 - D1 M6)
NewsBot
May 15, 2015 10:10 AM
May 8, 2015 11:30 AM
