Can a stock lt1 handle 9psi of boost
yeah id definitely be careful...9psi on an lt1 may only be possible with a good intercooler, the alky injection and 110 octane gas with a somewhat safe tune...id run no more than 8 until you get the new motor in
Well, i got mine to hold 10psi piston and ring wise. But the stock bottom end just isn't ment to hold that kinda power as it says in my sig ...
either go with 4-5psi which is still alot more power.. or start buying parts for the new engine.. it will go... sooner then you think. Mine lasted 2-3 weeks of maybe 6 hours of total running time.. maybe 20min of full throttle beating...felt good while it lasted. Now my car is sitting in hundreds of parts waiting for me to get the money to fix it
Stock 130,000 mile LT1 with bolt ons and a small cam - 8lbs of Vortech SQ-Trim boost for 1.5 years, raced 3 times a week before finally smoking the headgaskets. The ring lands went after about 8 months of boost - car ran great still.
Yes it can take as much boost as you want, but it's hard to say how long it will last.
I ran 9 lbs, it held for 2 years doing that racing every weekend. it finally dropped a valve from me getting valve float from all the 6800 RPM run I was making, I would see 10 lbs at 6800 RPM. if I wouldnt have reved it that high it would still be together.
Haha. I admit that I must be pretty lucky when compared to the others and their stories.
Wish I could remember the exact mileage when I put it on for reference but if I had to guess, I'd say it was probably around 65k. I drive it every day now so it has close to 100k if not more.
I credit the good tune, and common sense of the operator.
I keep a low temp thermo in it and won't run it hard unless it is cool. I wish everyone could have the same results with LT1s.
Knock on wood...I also have the same 10 bolt rear I snagged out of the same car I got the engine out of. It has been running Nittos for some time now.
I bet my junk breaks tomorrow, lol.
I keep a low temp thermo in it and won't run it hard unless it is cool. I wish everyone could have the same results with LT1s. Knock on wood...I also have the same 10 bolt rear I snagged out of the same car I got the engine out of. It has been running Nittos for some time now.
