CamaroZ28.Com Message Board
-   Forced Induction (https://www.camaroz28.com/forums/forced-induction-10/)
-   -   BOV question (https://www.camaroz28.com/forums/forced-induction-10/bov-question-881994/)
87Aerocoupe Mar 19, 2015 01:55 PM
BOV question
Hey guys I'm getting a D1SC for my 97 SS and I want to know if I can use a 50mm BOV designed for use on a turbo setup on the supercharger setup, don't want to pay $275 for Procharger's "race" BOV, thanks?
mzgp5x Mar 27, 2015 02:27 PM
Re: BOV question
Yes, they are a large price. I purchased (2) Bosch alum BOV, or, Bypass valves. I run two with an F1a Procharger. I run my MAF next to the air filter, so, I call them a bypass since the discharge must be re-introduced to the intake cycle (after the MAF).
I did have to re-cal the Bosch valve(s) springs for a 18 psi trigger point (zero vac assist). I paid $103 dollar over the inter_tubes. Got some new compression springs from Enco and cut them to calibrate for the 18psi.
I did an excel sheet to calculate the spring rate. Measured the force/ deflection rate and cut coils to match needed spring rate.
It can be done! B.
87Aerocoupe Apr 12, 2015 12:25 AM
Re: BOV question
Thanks I got the Ebay XSPower 50mm BOV.
