block fill and ks?
Old Dec 18, 2009 | 11:17 PM
4SFEDZ's Avatar
block fill and ks?
what is everyone doin bout their ks's when half filling their block?
Old Dec 19, 2009 | 12:16 AM
MikeGyver's Avatar
It probably still works fine.
Old Dec 19, 2009 | 07:48 AM
4SFEDZ's Avatar
the fill dosent cover up where the sensor goes?
Old Dec 20, 2009 | 10:46 PM
MikeGyver's Avatar
I may be wrong, I'm just thinking the metal block is still going to ring if you tap it with a hammer (i.e. detonation in the head). Moving the knock sensor above the fill might help, but also changing it's location could be bad too.
Old Dec 21, 2009 | 01:19 PM
4SFEDZ's Avatar
could i fill it then just drill thru the material so that the water can still contact the sensor?
Old Dec 21, 2009 | 11:27 PM
MikeGyver's Avatar
You're talking about a Knock Sensor, right?
Why would you need that to touch water?
Old Dec 22, 2009 | 08:03 AM
jsetzer's Avatar
Sound travels fine through iron.
Old Dec 23, 2009 | 11:55 AM
4SFEDZ's Avatar
i guess i was thinkin that water had to contact it for some reason. they why doesnt it just screw into the block and not go all the way thru? why did they make it thru the block into the water jacket?
Old Dec 23, 2009 | 12:15 PM
97WS6SCharged's Avatar
It's cheaper to request a sensor have a thread pattern that matches a hole that's already in the engine block than to make new molds to add another hole to said engine block.
Old Dec 23, 2009 | 12:57 PM
The Untouchable's Avatar
just fill it and make sure you do not use teflon tape to seal the threads because the knock sensor has to have a good ground contact with the block in order to give a good signal to the pcm , i have seen people use teflon tape and then get all kinds of knock retard thats all over the place
Old Jan 11, 2010 | 01:43 AM
Lisa33's Avatar
I put Silicon hoses true the KS and drain hole and up over the block, after the blockfiller had hardened i just pulled out the silicon hoses. Dont know if the sensors need watercontakt but its nice to have the possibility to drain the block.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
ad356
Apr 11, 2015 11:12 PM
Sandersen511
Jan 13, 2015 03:49 PM
