best way to remove blower pulley while on bench?? Help
Hey guys,
I have a new 8 rib dedicated drive system for my 95 vette and need to change the blower pulley over to the 8 rib pulley (P1SC).. need to know the best way to hold everyting still to loosen the pulley retaining bolt.. and if it is reverse thread or std threaded.. thank in advance guys!
Chris
Chris
Re: best way to remove blower pulley while on bench?? Help
Use an impact on the bolt, it may slide right off. If not then do as above and apply some heat with a propane torch for just a few seconds. Don't burn yourself. Use loctite 262 on bolt for the install.
SpeedJunkee
Jun 6, 2015 04:27 PM
