? about ati adjustable f.m.u.
Re: ? about ati adjustable f.m.u.
The needle valve adjusts the boost reference signal to the fmu. When you turn it in the signal is stronger and produces a quicker rise in fuel pressure. As the boost gets higher the adjustment has less of an effect due to the higher pressure in the line.
Without a wide band O2 sensor to measure your true air/fuel ratio, you're just guessing at FMU settings and risk blowing up your engine from a lean condition. Professional tuning on a dyno with a wideband O2 system is the best way to tune, including changing your fuel pressure if necessary.
I agree that your spark plugs are good indicators, but they're lagging indicators, not the real time feedback of a wideband O2 sensor. Also you need to pull the plugs right after the WOT run so as not to change the color of the plug on the drive home.
