3800 supercharger
3800 supercharger
I have been thinking. The grandprix gtp as the m90 on it. they use the same 3.8 v6 that is in the camaro. How much work is needed to transplant the setup from a gtp to a v6 camaro. the only spot i saw with a prob is the tb. it would be right next to, if not up against the fire wall. has anyone done this,
thanks
Frank
thanks
Frank
www.firebirdv6.com has talked about this many times.
Throttle body outlet would be on the wrong side.. only way I could see to do it is by using an aussie blower of a holden car or using an adapter that has the curve to allow the tb to be mounted in the right spot.
