Go Back  CamaroZ28.Com Message Board > Community > F-body Lounge
Nitrogen in tires? Anyone know anything about it? >
F-body Lounge All off-topic posts. Music, Sports, Movies, Humor, etc.
Please, no content above a PG-13 rating or political/religious content.
Old 04-06-2006, 05:51 AM
I was flipping through the channels, insomnia in full force, and caught the tail end of some news bit stating that there were some service stations that were filling up customers tires with nitrogen.
Anyone hear of this before? or had experience with it? The news fella said that it added 3-4mpg???? Sounds rediculous.
I googled it and found that it helps preserve the tire, and helps keep it at a more stable pressure, closer to spec. I guess that could help in gas mileage, but I dunno.
Carpe Diem is offline
Old 04-06-2006, 07:21 AM
Re: Nitrogen in tires? Anyone know anything about it?
I know in most autosports, teams use nitrogen in their tires because it gives a more stable pressure, and is not affected by outside influences at much. I.E. Humidity in the air.
It provides a more constant and predictable tire pressure, and this helps the teams make pressure adjustments precisely, without having to worry about it being inconsistent.
As far as better mileage, I have no idea. A wide factor of things goes into determining your mileage.
Brandon_Lutz is offline
Old 04-06-2006, 07:32 AM
Its mainly used in racing b/c as a tire heats up and then gets cold and back and forth through its cycles the nitrogen will not produce any moisture and also keep the tire pressure more accurate and consistent.
About the mpg??? Probly not but I might be wrong.
BlkLT1Z28 is offline
Old 04-06-2006, 07:34 AM
jawzforlife's Avatar
I heard the same thing on the news a few weeks ago
jawzforlife is offline
Old 04-06-2006, 07:36 AM
kick Z tail out's Avatar
It's good because if the T1000 tries to kill your mom, and blows out one of your tires in a volley of fire from his MP5K, he will freeze and be unable to move... which will allow you to fire the last round from your 1911 to shatter his ***.
kick Z tail out is offline
Old 04-06-2006, 07:53 AM
Freebird
Johnny Ray's Avatar
We used nitrogen in the 70's and 80's when we were racing.
I beleive just about everyone else was using it also.
Johnny Ray is offline
Old 04-06-2006, 07:58 AM
We still use it in our 355/360 challenge cars as well as the 333sp's
Old 04-06-2006, 08:08 AM
Super Moderator
JakeRobb's Avatar
Having your tires inflated to the proper pressure does improve gas mileage relative to having them underinflated or overinflated. The amount of improvement is going to vary depending on about a hundred other factors. 3-4mpg is a best-case estimate, probably compared to driving on tires with no air in them at all.
Atmospheric air is like 78% nitrogen anyway. No big deal here.
JakeRobb is offline
Old 04-06-2006, 08:56 AM
when I worked for advance auto, we started filling our delivery trucks up w/nitrogen, overall saved the company a bunch of money per this newsletter thing for employees...
longer tire life and slight better over mpg, worth it in the long run for a company trying to make money/save money on every possible front
coogsLS1 is offline
Old 04-06-2006, 09:03 AM
i use helium because it makes the tires lighter. that increases fuel mileage and acceleration
formulaofsuccess is offline
Old 04-06-2006, 09:06 AM
Originally Posted by robvas
Doesn't it leak faster because the molecues are smaller?
i use gorilla glue on the beads and valve stems
Old 04-06-2006, 09:44 AM
Zack's Avatar
3-4 mpg from nitrogen tires
2-3 mpg from fuel system cleaner
3 mpg from royal purple oil
2 mpg from K&N air filter
3 mpg from performance exhuast
2 mpg from a magnet on your fuel line
3 mpg from a net instead of a tailgat
50mpg mother ****ers
no tornado?!
Zack is offline
Old 04-06-2006, 09:47 AM
Threxx's Avatar
Costco uses nitrogen.
I could see getting 3MPG from nitrogen if you filled one car's tires with nitrogen and one with regular air on a 100 degree day in the middle of the summer and then come a zero degree day in the middle of the winter you'd never bothered to adjust the pressure... the air filled one would be way low on air pressure, and air pressure can easily make a 3mpg difference.
But realistically it just keeps you from having to worry as much about temperature changes affecting your tire pressure.
Threxx is offline
Old 04-06-2006, 09:57 AM
SliderZ28's Avatar
They use it in jet plane tires because it is not affected as much by temperature as regular air.
SliderZ28 is offline
Old 04-06-2006, 10:30 AM
you need all the help you can get with that honda
Quick Reply: Nitrogen in tires? Anyone know anything about it?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
