Go Back  CamaroZ28.Com Message Board > Community > F-body Lounge
need to glue/repair plastic, but this glue says not to use >
F-body Lounge All off-topic posts. Music, Sports, Movies, Humor, etc.
Please, no content above a PG-13 rating or political/religious content.
Old 03-11-2008, 10:46 AM
jawzforlife's Avatar
At work, an arm broke pad off one off our chairs. It should be an easy fix with some glue. So I went to the store and got this
On the front is says "Glues together, Whatever bonds together"
but on the back in small print, which I didn't see until I got back to work.. it says "not recommended for use on polystyrene or polypropylene plastics.
I did a little search, and looks like those type of plastics are the most common household plastics (which i assume the chars arm is made out of). What kind of luck will i have on using this glue on plastic?
jawzforlife is offline
Old 03-11-2008, 11:06 AM
z28Power's Avatar
I think that warning is put on there because some of the chemicals in that particular type of glue can sometimes melt plastic
z28Power is offline
Old 03-11-2008, 08:02 PM
i think u would be better off using an appropriate epoxy.......sets up faster and stronger
lastZ is offline
Old 03-11-2008, 08:25 PM
Classic Tech Moderator
Erik's Avatar
Your chair is definitely not polystyrene (egg containers, packaging foam) and is very unlikely that it's polypropylene (food containers, plastic cups, plastic cutlery, car battery housings). I wouldn't hesitate to use it.
Erik is offline
Old 03-11-2008, 08:28 PM
Good Ph.D's Avatar
Go ahead, what's the worse that could happen?
The glue create some kind of wierd chemical reaction and release poison gas I guess...
Good Ph.D is offline
Old 03-11-2008, 08:37 PM
Eric Bryant's Avatar
Well, I agree that it's not polystyrene (which is rather weak and brittle - it's what plastic models are molded of), but there's a very good chance that it is indeed polypropylene. When blended with the right filler (such as talc or glass fibers), polypro is tough, strong, and cheap - ideal for all sorts of consumer applications. We use a lot of it at work for structural automotive components that don't require the high-temperature properties of nylon.
The problem with something like Goop is that it can't chemically bond to polypro, so the only bond will be mechanical - and Goop doesn't form an exceptionally strong mechanical bond. The best bet would be to use an epoxy with a long set-up time (as the so-called "five minute" epoxies aren't very strong), and make sure to roughen up all the surfaces with coarse sandpaper or a rasp. Odds are, though, that the bond will not be satisfactory without some sort of mechanical reinforcement (rods, plates and screws, a wrap with fiberglass cloth, or something similar).
Eric Bryant is offline
Old 03-11-2008, 08:54 PM
JP95ZM6's Avatar
Polypro is slippery, and pretty solvent resistant. Thus it can't be glued or solvent welded very easily. Either weld it (heat to melt and mash together) or try to drill and pin it like a busted legbone.
It only has to hold together long enough to swap it for somebody else's chair, after all....
Edit: Hot melt glue is a decent compromise, too. Use the hard/extra high melt stuff.
JP95ZM6 is offline
2QUIK6
09-17-2016 02:31 PM
War Engine
08-28-2015 06:04 AM
TGGodfrey
08-17-2015 08:43 PM
Quick Reply: need to glue/repair plastic, but this glue says not to use
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
