honey comb shaped object out of exhaust
I have a magnaflow cat back system on my car, I pulled out a peice about 1.5inches in width and 2-3inches in length of a honey comb shape out of my tail pipe. Would this just be a packing of my exhaust or would it be part of the cat?
Re: honey comb shaped object out of exhaust
That's the start of the matrix breaking up. I would not suggest doing nothing..ther is a possibility that the exhaust will get plugged up as things move around. If you don't want to replace the cat, pull the y-pipe and remove the remaining 'stuff' by poking it and banging on the case and dumping the stuff out....
The LAST thing you want to do is nothing. If another piece breaks off and turns sideways, guess what? You exhaust is blocked. You're on the right track in getting it replaced!
Well, I looked under the car, and the one has already been replaced! Is there anyway of telling what cat it is? I could just pull off the cat back system and look into it? Where can I get a decently priced cat?
drptop70ss
May 4, 2015 08:22 PM
