Header Install
Old Feb 27, 2007 | 08:47 AM
NTRBTR97Z's Avatar
Header Install
Anyone know what it costs to install a set of pacesetter race headers and Y-pipe?
Old Feb 27, 2007 | 10:11 AM
2tight's Avatar
around $500 to 1k
Old Feb 27, 2007 | 10:23 AM
'94 Bad A Z28's Avatar
It costs absolutely nothing to install PaceSetter LT's and Y-pipe. But to buy them is another thing, if I remember correctly I payed $480 shipped my mine.
Old Feb 27, 2007 | 10:43 AM
2000GTP's Avatar
When I had the cats welded into my y-pipe, I asked the guy how much a header install usually runs. He said it runs around 650-800 depending on the complexity.
Old Feb 27, 2007 | 10:54 AM
BlackScreaminMachine's Avatar
Free, do it yourself.
Old Feb 27, 2007 | 10:55 AM
vdubois's Avatar
it cost me 350.00 to get my headers installed and the guy said it took them over 5 hours. Yes you can do it at home but man does it suck. You also need to be underneath the car and you may need to do some welding.
Old Feb 27, 2007 | 11:08 AM
LiENUS's Avatar
You can make life a little easier if you back out the 3 bolts holding the cross member up, you can lower it by up to an inch i believe safely, remove the long bolts holding the motor mounts together and jack up the motor a couple inches, this should give you extra room and allow you to move the engine a little to the left or to the right to fit the headers. Also buy a can of pb blaster and start soaking the bolts now, both the ones where the manifold meets the head and where the manifold flange to the rest of the exhaust system is, youl'l need it. For the flange bolts if they are overly stuck get a long extension and slip a 4 ft pipe over the handle of your ratchet and have a friend turn the pipe while you hold the ratchet on the bolt, a similar trick should work for the bolts holding the manifold to the head but I don't know for sure as I have not done longtubes on my bird yet. Chain link fence posts (the ones that run along the top of the fence) are idea for this, they're easy to cut with a hacksaw and they fit perfect on most ratchets.
Old Feb 27, 2007 | 11:15 AM
BS, it took me an hour and a half in my garage on jack stands and I have never done headers on anything before this.
Old Feb 27, 2007 | 11:25 AM
LiENUS's Avatar
My bet is the the guy quoted the book for manifold r&r and y-pipe r&r. He probably spent significantly less time on it but charged him for the 5 hours it would take to do manifold and y-pipe separately. I find it hard to believe that the time book would say 5 hours for the two of them but i've seen some crazy numbers in some of those books.
Old Feb 27, 2007 | 11:56 AM
LTgun_94's Avatar
Ive heard of worse. Installation of longtubes can be a pain, Ive heard!
Old Feb 27, 2007 | 12:40 PM
convertz's Avatar
My RK Sport's took me a while, my big *** hands didnt fit in the tiny places they needed to
I would think with a lift its significantly better
Old Feb 27, 2007 | 12:55 PM
Z95m6's Avatar
I'm sorry but i'm gonna have to call total BS on this. It would take much longer than this. I'd say 4-5 hrs minimum to them. I'd never allow anyone to work on my car with out my supervision. I could just see getting the car back and there be bolts broken off in the heads and other things broken/not installed correctly.
Old Feb 27, 2007 | 02:23 PM
ev95355's Avatar
oops
Old Feb 27, 2007 | 02:25 PM
2000GTP's Avatar
The long tubes are trickier, you have a very bulky header that you have to wedge into a very tight, confined space. I wouldn't consider them to be alot more difficult versus the shorties or mids. I think the hardest part of the job for me was just removing all the old hardware and not snapping off any exhaust manifold bolts in the head. Once I got through that step, everything else was smooth sailing.
ev95355's Avatar
Total BS, i've done it 8 times and theres no way to do it in an hour...
