picture of stock dual cat exhaust?
Does anyone have a picture of stock dual cat exhaust? I'm trying to figure out how the exhaust hanger bolts up to the y-pipe under the passenger seat. Seems like something was bolted to the crossmember or tranny tunnel somewhere, and then a hanger was stuck through that?
Shoebox has most of this stuff.... no one ever seems to check there first:
http://shbox.com/1/exhaust_system_dual_cat.jpg
I also searched the forum for the words "stock exhaust" but didn't find any photos. I'll try researching with some different terms.
IIRC, the other side of that bracket (on the other side of the tranny) is the torque arm bushing. The bolt(s) go all the way through the tailshaft. It's a bit of a bugger to work on, IIRC it is easier if you drop the rear of the tranny a bit so you can get wrenches on it.
Ace, any new pics?
Is the top of the bracket right next to the bolts for the torque arm bracket (bolt heads - the actual TA bracket is on the other side of the tranny)? I know on the earlier years, that's where the support bolted, as was indicated in a post above.
