Won't downshift
Camaro won't downshift into second over 35 mph. Could it be tps?
Sent from my LG-LS860 using Tapatalk |
Re: Won't downshift
Swapped the tps into my ta and it works fine. Any other ideas?
Sent from my VS920 4G using Tapatalk |
Re: Won't downshift
Original transmission?
Frank |
Re: Won't downshift
No it was just rebuilt recently
Re: Won't downshift
Did they rebuild your unit or sell you a different trans?
Frank |
Re: Won't downshift
It was a unit i bought off Ebay rebuilt. It was junk, had it rebuilt again. It was a stock rebuild with a shift kit. Probably not a good idea.
It worked fine. Sent from my VS920 4G using Tapatalk |
Re: Won't downshift
Most likely, you have a '96-up trans in the car. GM changed the downshift strategy in '96. It was different than the '95. They have a different resistance downshift solenoid, valve body, and separator plate.
Frank |
Re: Won't downshift
It didn't do it when it was in my ta.
Re: Won't downshift
And it was fine in the Camaro until it sat for 7 months.
Re: Won't downshift
Any codes?
Re: Won't downshift
Clean the maf and reset the pcm. Mine does that occasionally when the maf gets contaminated.
