will balancing the D.S. get rid of the high speed shudder?
at 100mph or so my stock drive shaft has the common shudder problem. Will balancing cure it? A local heavy truck shop can do do it for around $70
If you want to keep the strength of your steel DS (stronger than an LS1 aluminum), have it balanced. If you have recently had it off, you might try unbolting it and rephasing it 180° and see how it feels.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
stockssn2o
May 25, 2015 08:54 AM
