why is my car not shifting right at WOT?
Old Aug 31, 2005 | 01:52 PM
93CamaroZ's Avatar
hey guys, i just got a set of longtubes and y pipe for my car and i went out to run one of my friends last night with a 97 z28 to see how the imrovements were. we ran twice from a dig and everytime my car would get up to like 5k it would almost sound like its hitting the rev limiter or something (my car was in OD). it did it going into 2nd and 3rd both times. i started to think it might be ignition but my new opti of last year has 7k miles on it, and i just got brand new ac delco plugs and wires when i had headers installed. it seems like the same thing has happened before but has been a couple years. whats the deal? one of my friends said it could be the tranny. btw, it shifts just like normal during daily driving....it only hesitated around 5k or so.. could it be my fuel pump maybe?? i just read an article in GMHTP about an LT1 car losing power in WOT due to fuel pump, which was replaced by a new Racetronix pump.
Old Aug 31, 2005 | 07:12 PM
93LT1355's Avatar
Re: why is my car not shifting right at WOT?
Incorrectly set TV Cable?
Old Aug 31, 2005 | 07:47 PM
Paul87's Avatar
There's no TV cable on 94+ cars, but good thinking
Old Aug 31, 2005 | 08:21 PM
TransAm9585's Avatar
More then likely your tranny is on its way out the door. Take it to a tranny shop. Most do free estimates. CHeck the fluid also. If looks burnt then more then likely your going to need a rebuild. I had the same issue with mine and then one day BAM it was dead all together.
Old Aug 31, 2005 | 08:22 PM
Janny's Avatar
Tranny is likely slipping.
Dial back the shift point a bit and raise the rev limiter a bit then quit racing everything you see and you'll probably be able to go quite a while with it while you save your money for the 6 speed swap.
At least that is what I did.
I got 2 more years of summer fun out of it.
Old Aug 31, 2005 | 10:18 PM
pHEnomIC's Avatar
whats the reason to increase the limiter while lowering the shiftpoint? Just wondering. Is it to make absolutely sure that it wont hit the limiter?
Old Aug 31, 2005 | 11:04 PM
chrism400's Avatar
Pretty Much!
Old Sep 1, 2005 | 12:53 AM
amean94ta's Avatar
mine does this at 6300 my rev limiter is 7100 i think i am not getting enough fuel or spark
Old Sep 1, 2005 | 11:13 AM
WS Sick's Avatar
Yeah the old upper rpm slip...lol. My only flag I see that crosses me is that you say its at like 5000 rpm, no where near the rev limiter. If your valvetrain is in good order a lean miss or ign related mis is realy about the only options.
Old Sep 1, 2005 | 12:00 PM
FatalZ28's Avatar
Yeah, my friends 2001 Silverado that was modded did that. It would drive around just fine if you werent getting on it. Once you put the pedal to the floor it just wouldn't shift. IDK what the problem was b/c he de-modded it and sold it before getting the tranny fixed.
Old Sep 1, 2005 | 12:04 PM
Janny's Avatar
The more that thing slips the sooner it will me toast. So don't let the motor get near the limiter because it will start bouncing off the limiter putting even more strain on an already weak tranny.
If you've ever heard a 4 cyl. Honda bouncing offf it's rev limiter you'll understand.
Old Sep 1, 2005 | 01:14 PM
amean94ta's Avatar
i dont think its his trans guys like i said mine is doing close to the same and i know my 300 mile pro built 4l60e aint going. before you go get a rebuild and end up with the same problem get a fuel pressure gauge on there tape it to the windshield and go hammer it if it drops below 40 psi get a new pump or add a booster
Old Sep 1, 2005 | 03:50 PM
MyTMous's Avatar
the guys screenname is 93cameroZ, so I could see the TV comment,
as he didn't say what year he has I would also so TV cable.
It could have got bumped or something, it was a Bitch getting mine setup right, and yes I have a 700R4 in my 94, but I put it there, it was a 6 speed.
Old Sep 1, 2005 | 05:23 PM
93LT1355's Avatar
Yeah I was under to impression he was talking about his car, and the screen name gave me 93
jayblev95
Jan 20, 2015 01:30 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
