Which size rear end?
Im lookin at buying a rear end that can handle atleast 450hp from the engine. And later I might put afr heads and a supercharger with alot of boost. Right now the choices are a Moser 12 bolt, Strange 12 Bolt or a Currie 9 inch. The cheapest of the three would be the Strange which comes with my choice of gear. 33 spine axles SS posi and a TA girdle. Next would come the Moser 12 bolt with the same options. And finally the Currie 9 inch with 35 spine axles. All of them come with the posi, my choice of gears. Can the Currie 9 inch accomodate stock camaro rear disc brakes off of a 95 z28? Obviously the Currie is stronger, but how much can a 12 bolt hold? Money is not really a problem, i'd rather spend alot now than double later. For my combonation which would make at most 900hp. Will the 12 bolt hold it for an extended amount of time?
Re: Which size rear end?
Originally Posted by n2ceptor
I have seen a few threads in the Drivetrain Section..... Might try searching there..
10-31-2016 11:09 AM
