What to get first
What to get first
3.73's or 4.10's- im thinkin 4.10s i never generaly have a reason to go over 115 or what ever the auto will top at, or a B&M Hole shot 3K stall with transmission cooler, or a zenith 27" HDTV?
Between gears or stall converter what will be a bigger bang for the buck
in my opinion 4.10s are too much for auto cars. i have 2 friends that have them in A4s.....one blew up 2 rears and cant go faster than 112 mph (you may not have a reason to go over this speed but i trap 111 with a stock engine so you can see you'll eventually run out of gear when you start going faster....plus gas mileage SUCKS and you'll wear stuff faster since the motor/drivetrain are always spinning like crazy) and the other hated them so much he took them out after a month and swapped in 3.42s....
also, just something to think about, i've heard bad things about holeshot converters...go with a TCI, vigilante or Yank. they are more expensive but definitely better quality.
also, the converter will give you bigger gains without a doubt (assuming you do get a 3000+ stall).
Rkrause said you would still be able to run 125 if you wanted too, i dont think you will top out an a4 at 112, maybe if we had the old 4 speeds with 4.56 gears like the ls6 chevelle sure, but i dont think i buy into only going 112. what i read the biggest complaint is gas, the next is concerning both 4.10's and 3.73's saying they dont drop as many gears. Unless you only meant 112 in 1/4 mile which that doesnt matter im never at one!
I am not sure what you are asking? If there is no speed limiter set in the PCM, your top speed will be limited by the rev limit and the amount of hp you have available. In the case of an A4 with a 26" tire, 6,000rpm would be 178mph in 4th gear with 3.73's and 162mph with 4.10's. Subtract a few mph for converter slip. But you still need the power to go that fast.
Thats what Rkrause said to me in a differnt post.
like i said i had 2 friends with 4.10 geared A4 LT1s....one said he could do almost 120 before running out of gear and one said they could do 112-115..... in either case 162 is out of the question. the more power you put through the drivetrain the more of it is going to be lost to slippage. besides LS1 f-bodies are electronically limited to 162 mph anyway regardless of gearing. there is a fuel cut-off programmed in. LT1s have one at around 155 or 157 or so i believe.
