Well, it looks like my SLP clutch is toast...
I'm running street tires too. :( I powershifted 4th at 6500 RPM's today, and the RPM's never dropped below 6200 in 4th gear. :mad: Has anyone had any experience with the mcleod disk with the slp pressure plate and stock flywheel? And how does it drive, and what kind of power are you putting down with it?
Re: Well, it looks like my SLP clutch is toast...
Might want to consider a Spec disk from LMperformance.
They go for around $150. Your pressure plate is the same as the Spec plate but you got the holes. Sounds like you need a stage 2 or 3. Dont know much about the Mcleod. |
I've heard too many stories about the spec's breaking their springs, including my best friend when his car was just h/c, so its either mcleod, ram, ect...
stage 4....no springs ;)
| All times are GMT -5. The time now is 12:46 AM. |
