CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   Weird Observation (https://www.camaroz28.com/forums/drivetrain-44/weird-observation-680018/)
hairbear21 Apr 9, 2009 10:58 PM
Weird Observation
I was replacing my axle bearings, and when I was putting everything back together, I noticed something that I don't know is normal. When I turn the differential, the carrier bearing races are turning. This doesn't seem normal to me, and I'm wondering what can be done if the races aren't supposed to turn. Can I replace the bearings and races, or am I going to wind up doing an entire rear end job?
Kevin Blown 95 TA Apr 10, 2009 10:13 AM
in that case, you might try some locktite RC609 bearing retaining compound.
hairbear21 Apr 10, 2009 02:18 PM
Would I still have to go through the whole process of setting preload, backlash, etc...?
hairbear21 Apr 12, 2009 10:00 PM
Well, I found a rear end with 3.42's (mine has 3.23's) for $300. This also includes a 200 day warranty with the option to purchase a longer warranty. The only downside is that I'd have to swap rear ends. I have the tools to swap the rears, and I figure that cost-wise, it'd pretty much be a wash, and I get the warranty too. I'm thinking hard about this, plus, it'll give me a good reason to go with Tuner Cat to adjust the speedo, and do some other stuff.
