trans temp
what temp should my tci 700-r with a 3200-3500 stall be running at?
Re: trans temp
Most people like to see less than 180 degrees. If it's more, you need more cooling.
Rich |
Re: trans temp
with my b&m cooler it seems to stay alittle below 180 when im beating on it and around 150 on the highway does that sound about right? also what temp would you say its dangerous and i should shut the car down?
Re: trans temp
Rich |
Re: trans temp
lastnight i noticed it get up to 245, i was real close to a freinds house so i limped it over to his house for the night. anyclue what could be causing this? there is a was a very slow leak on one of the hoses hooked to the trans cooler that we fixed this afternoon but i dont think that would cause it to heat up that much.
| All times are GMT -5. The time now is 06:11 AM. |
