tranny whining after gear install
Old Jan 7, 2006 | 10:26 PM
seawolf06's Avatar
I thought it was the gears, but after a friend rode with me, he said it was the transmission. It started the day I put gears in (4.11). It whines during acceleration and braking, but not coasting. It's loudest when I'm only partly on the gas to maintain speed in 6th, but does it in every gear. Very little ds vibration at higher speeds (above 80 mph). Clutch is relatively new zoom clutch. Everything was professionally installed. Any ideas? Thanks.
Old Jan 7, 2006 | 10:52 PM
Cmr0z28's Avatar
Re: tranny whining after gear install
Sorry, but I don't see how rear-end gears would make a transmission whine.
Old Jan 8, 2006 | 06:19 PM
seawolf06's Avatar
I don't either. It could be the shop, although they did point it out to me, or it could have been unnoticable before, and now it's just louder. That's why I wanted to see if anyone might have an idea.
Old Jan 8, 2006 | 10:20 PM
T56Rebuilds.com's Avatar
If changing the rearend caused the tranny to start whinning that would be a first for me. I would lean more towards gear whine in the rear. I have 3 vehicles and after changing the gears in all of them they have gear whine. You should be able to tell the difference and if it is coming from the tranny that is interesting. You might what to have it looked at if it is the transmission before the problem gets worse. My experience tells me that the longer you wait the more expensive it is to fix.
Thanks,
Joe
832-488-0533
ddr698
Jan 9, 2015 10:05 AM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
tds1213
Nov 27, 2014 12:55 PM
Snoman73
Nov 17, 2014 07:22 PM
