Tranny (VSS) Issue...
Well I am needing to get the vss figured out on my 94 Camaro Z28 A4.
The engine/trans are 97's but the pcm/wiring harness and the rest of the car is a 94. So would I still just need to swap a 94 tailshaft onto my 97 tranny? can you not just change the connector?
Thanks!
Thanks!
93-02 tailhousings are all the same for the T56 in F-bodies. The VSS connector is different between a 94 A4 and 97 M6. In 96, the A4 connector was changed to match the T56 VSS connector.
The part number is 88987993. It will show up as "Brake Master Cylinder Reservior Hardware" on gmpartsdirect, but that is the correct part number as far as I know.
so would just swapping the wiring harness connector work or does the tailshaft have to be changed out to make it work?
Also would the tailshaft off a 94 V6 tranny work or are those different than the ones on the V8's?
I did exactly what you are doing. Go to the autoparts store and get a coolant temp sensor connector plug(the one on the water pump) wire it in and plug it up. Does not matter which way it is wired either.
This is for a 96-97 4L60E tail housing.
David
David
