tranny toast ? 4l60e tranny
Subscribe
Sep 29, 2004 | 04:10 AM
When i drive around town it hits hard and firm shifts. But if i floor it it will hang slip like crazy up top and just hit the rev limiter but if i let off it will shift immediatley. Once it shifts it pulls hard in the gear. Also its weird cuz if i shift it manually it doesnt pull right. For example, If i put it in first and give it gas it will pull but if i let off the gas the rpms drop to idle but if i touch the gas it slams back up like i downshifted a manual. Almost like its in neutral unless im hittin the gas. Weird stuff never had an auto act like this before. If i shift manually it hangs as well untill i let off the gas. I checked the fluid and it was fine then the next day i checked it and it was a little over a quart low. Is that common to lose that much fluid in one day ? I've checked for leaks and i cant seem to find any. I've checked the fluid everyday for about a week and its been the same "FULL". Is my tranny toasted and need a rebuild or loose wire ?? any suggestions? tranny has bout 70k miles on it. Thanks
corey
p.s. this is a 4l60e from a 94 camaro
Reply
Subscribe
