torque for tranny pan bolts
Old Jul 18, 2004 | 01:22 PM
bigfoot2471's Avatar
i have a leaky tranny pan and i bought a new gasket. when i went to take the bolts off for the pan all the bolts seemed very lose. they took very little pressure to break them lose almost none. so i was just wondering if they are supposed to be torqued that lose and if thats the reason i was leaking. thanks
Old Jul 18, 2004 | 01:57 PM
lastlaf's Avatar
I found that my tranny pan bolts had a way of working themselves loose over time likely from vibrations. So I kept snugging them up and eventually put a little loctite on them to keep them from backing out. That's likely what has happened to you. They should be snug.
Old Jul 18, 2004 | 02:03 PM
that makes sense cause it started leaking a lot more heavily after a 75 mile drive averaging 80-90 mph. so if i just tighten them all up would that solve my leak or should i just go ahead and replace the gasket? thanks again
Old Jul 18, 2004 | 09:12 PM
revtime's Avatar
Re: torque for tranny pan bolts
No more than 12 ft lbs.
use an inch lbs torque wrench.
I would try retorquing the pan bolts first before I put a new pan gasket on.
Old Jul 19, 2004 | 12:11 AM
Loadre's Avatar
Yup, 12 ft lbs. They aren't supposed to be all that tight.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
VF-124
Mar 16, 2015 08:14 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
