Torque specs
What are the torque specs for everything related to changing out the clutch. Thanks.
Re: Torque specs
Flywheel bolts- 74 lb ft
Bellhousing - 35 lb ft Trans Bolts- 26 lb ft Pressure Plate- 22 lb ft Slave Cylinder- 15 lb ft That should be everything. |
Re: Torque specs
Thanks!! BTW, did you pull the bell housing off when you did it? I didn't do it last time, but didn't know if it would be easier.
| All times are GMT -5. The time now is 08:40 AM. |
