torque arm bar removal, help please!
Old Dec 29, 2003 | 10:03 PM
matto1225's Avatar
hey everyone, im taking off the rear torque arm bar and i got the one bolt off the differential, but the furthest one back(same exact bolt size) is like jammed in there, i got the nut off but i cannot get the bolt out, the other one slid right out after the nut came off, but this ones like frozen in there, is there any tricks to getting it out? i can get a good bite on top of the bolt but there is not much room to put a cheater bar on or anything, any ideas or anyone have this problem, thanks
Old Dec 29, 2003 | 10:13 PM
revtime's Avatar
Do you have the front of the TA unhooked?
Old Dec 29, 2003 | 10:16 PM
matto1225's Avatar
i have the bolts in the front loosend but i believe you have to take the torque arm off the back and slide it out backwards right? i cannot take the front off because if i try removing it, it hits the body of the car, see what im saying? i gotta take the back off and then slide the arm out, then lower the tranny
Old Dec 29, 2003 | 10:37 PM
revtime's Avatar
Try putting a jack under the rear and moving it up to try to get the bolt unbinded.
You might also have to get a punch and hammer the bolt up and out.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
