CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   Swaping rears? (https://www.camaroz28.com/forums/drivetrain-44/swaping-rears-273892/)
RobZ Jun 19, 2004 10:13 PM
Swaping rears?
Hello I need to know If it is possible to install a rear out of a 00 Z28 with Traction control on my 01 Formula with the non Traction control.I beleive to what im reffering to is that the 00 z28 (3.23) with traction control is a 4 channel and I guess mine would be a 3 channel deal.Any of you guys know what would I need to make the rear work?I dont need to Traction on.
Capn Pete Jun 20, 2004 09:51 PM
What gears are currently in your car, and what gears are you getting?
The problem is, a diff without trac-control has a blank where the ABS sensor needs to go on the top of the pumpkin (directly above the reluctor wheel that's mounted beside the ring gear). The trac-control diff uses axles with reluctor wheels at the outsides, near the wheel hubs. I think it would be easier going from non-trac-control to a rear with trac-control, vs. doing what you're doing. If your car currently has 3.23's though, and you're getting a 3.42 rear end (just guessing? for example) I'd suggest just swapping the ring & pinion, but if you've currently got 2.73's, and you want to put in a 3.42 diff w/trac-control (even though you'll be eliminating the trac-control) I think you could probably drill out the hole where the ABS sensor nees to go, and then you'll have to swap axles I think, to use the axles without the reluctor wheels?:confused: Oh, but then you'd still need the reluctor wheel on the carrier:think:......hmm, I dunno if those can be swapped or not?:rolleyes:
I think you should look into doing a ring & pinion swap, cause I think it'll be too hard to make the trac-control rear end work for your normal 3-channel ABS rear?:(
RobZ Jun 21, 2004 04:22 PM
Wow im a little confused,I think Ill stay away form doing this swap.Sounds like alot of hassle.thanks for your input.
Capn Pete Jun 21, 2004 07:11 PM
Sorry, I'll try to keep it simple;).
What gears do you currently have? 2.73's or 3.23's?
If you currently have:
A) 2.73's --- don't use that rear end.....buy the ring & pinion gear set for the ratio you want (ie: 3.42, 3.73, whatever). 2.73's use a 2-series carrier:thumb:.
B) 3.23's --- get that other rear end, but just take the ring & pinion and put them onto your current 3.23 carrier. 3.23's use a 3-series carrier, so gears such as factory 3.42's will bolt onto the 3.23 carrier no problem:thumb:.
RobZ Jun 21, 2004 09:09 PM
Great I get it now.Yes I have the turd 2.73 gear and I guess Ill start looking for some 3.73's.Thanks alot
