Stripped bolt in Aux Valve body, HELP!
I was putting my aux valve body in my 93 Corvette 4L60, when the bolt (long one in picture, wouldnt even start. I took it out and the threads were gone. Then I measured the distance up to where it bottomed out and this bolt seems longer than the hole. But, it was there when I took it out as it was the one with the tab to hold the aux body hydraulic tube down.
My question is , can I tap it? Or put a slightly larger bolt in? Thnaks in Advance http://i33.photobucket.com/albums/d8...h/DSCF0351.jpg |
The correct way to fix it would be to heli-coil it, but there's a few threads left in the bottom of the hole that MAY hold a slightly longer bolt.
Frank CPT |
Originally Posted by 12SCNDZ
(Post 4620925)
Frank CPT |
How did you make out Steve?
Originally Posted by Pete Kane
(Post 4625733)
Yes Pete, I am all over the net when in crisis mode. :( |
Originally Posted by RACEON
(Post 4627967)
Well Pete, I put a new bolt in with a slighlty larger thread, same depth. Went quite well. Then of course you know about the 4 gear accumulator ppiston pin I found later :)
| All times are GMT -5. The time now is 01:00 AM. |
