Spec Stage 3 or 4 clutch. Please help me decide.
Re: Spec Stage 3 or 4 clutch. Please help me decide.
Sorry I didnt update. I went with the Spec Stage 4 with the carbon fiber disc. It is really grabby, but not as bad as a ceramic would be. There is 0 clutch chatter. Since it is an unsprung clutch the clutch is very grabby, I drive mine daily here since I have put it back together, even in rush hour traffic. The clutch manors are great, you just have to rev your motor a little higher before leaving the line so you dont either stall the car or get that horrible jerky feeling. I rev the car to 1400rpm in order to get the car moving, this is also partly due to my gm847 cam.
Kendall
Kendall
Kendall
Kendall
I consider myself a bit on the conservative side. I was skeptical about getting the Stage IV for the reasons you mentioned. However, I decided to get it, and I love it. Yes it will have a firm pedal, The either on or off type of engaging mechanism you hear about, it's not too bad. It will last a short time as you break it in, and you get used to it. This clutch will hold up pretty good at almost anything you throw at it. That's what I like about it. So far, it has exceeded my expectations.
-Goose
-Goose
-Goose
-Goose
Any track passes on it Goose? I have spec stage 4 that needs to go in when I get around to it.. just curious.
-Goose
