should I flush the tranny or not?
I have an SS and I am about 43k miles on it. I bought the car in May and I do not know if he had it flushed or not. Should I just get the tranny flushed or change the fluid. It would hurt to just get it flushed would it? Thanks
Well the stuff GM puts in is that "100,000 mile" stuff. I just changed mine, and I have 105k. I did it simpily because I was putting a new clutch in. Keep it in, your fine. Wait till you swap out your clutch. to empty it, remove the 2 bolts on the passenger and driver side of the trans (use a 3/8 drive + extension (no socket). Cap it back, and fill it with about 4 qts of Dextron III (I THINK thats what its called) through the shifter housing.
