Shifter For 4l60E
Old Sep 5, 2004 | 10:09 AM
Ripcurl3249's Avatar
Shifter For 4l60E
Is there a shifter i can get so i can shift my self through the gears. cause i hate my i can only shift 2 to drive. would i need anything else to make it shift like that.
96 Z28 Camaro
Old Sep 5, 2004 | 02:48 PM
ABA383's Avatar
Re: Shifter For 4l60E
Your stock shifter isnt the problem. Its the little molded plastic stop on the shifter gate under the console that wont allow the shifter to go all the way back to 1. Take off the console and pull the shifter all the way back you'll see the stop holding back the shifter on the passenger side of the gates. Take a hack saw blade and cut it off...You can now pull the shifter all the way back to first gear...If you want to get fancy find a a new/used console from an A4 car that came with 3.23s...The gear selector will list 1 thru D...good luck...
--Alan
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
CARiD
Sep 7, 2015 08:21 AM
