CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   shift jump (https://www.camaroz28.com/forums/drivetrain-44/shift-jump-280097/)
Sceanzo Jul 8, 2004 09:35 PM
shift jump
today i pulled away from a stop sign (slowly) and turned left and it jumped a lil and then again in second. but now driving slowy it doesn't do anything
when launching or taking off from a stop it jumps/pops, it feels like its comming frmo the passenger back wheel side.
when you HIT the accelerator it jumps and jumps going into second. driving normally it doesn't do it.
I hope this helps narrow it down some
thanks
wwarnke Jul 9, 2004 06:22 PM
is it tranny or rear end?
hold car in first gear and see if it does it
open diff or posi or locker?
may be broken gear teeth on ring gear or snapped axle
Sceanzo Jul 9, 2004 09:39 PM
I did forget to mention that it is an A4
if that makes your reply any different
if it doesn't what do u mean but hold the car in first?
wwarnke Jul 9, 2004 11:39 PM
place your shifter into 1
this will keep the tranny from shifting, or at least it will not shift until a much higher rpm
I am trying to see if what you are experiencing is coming from the tranny or the rear end
