Royal Purple Vs Mobil1 vs Red Line
Hello All,
Time to change the rear gear oil and my vehicle calls for 80W-90, (87 Camaro Z-28-stock rear) but I was wondering if I can put 75W-90 Synthetic and which one is the best out of the listed 3.
I called Royal Purple and spoke to tech support and they said I can run 75W-90 with no limited slip additive and I shouldn't have any problems since their oil has same included with it. I don't know about Mobil 1 and Red Line.
Any responses would be appreciated
Re: Royal Purple Vs Mobil1 vs Red Line
I have heard that with a clutch type limited slip differential that you want to use conventional oil with additive, not synthetic. Maybe someone else will chime in to either confirm or deny this.
I like Redline Shockproof Heavy myself. I used it for several years in my 95 Formula with lots of 1/4 mile and roadcourse events and never had a problem out of the rear. It has the friction of a 75W90 but the film thickness of a 75W250. Also, it does not need limited slip additive (already built in) and works just fine with clutch type LSDs.
Originally Posted by Black5.7TPI
How well would these products work in my stock rear???
http://www.redlineoil.com/products_g...61&subcatID=20
phantasm99
Aug 28, 2002 11:01 PM
