CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   Reverse Lockout Question (https://www.camaroz28.com/forums/drivetrain-44/reverse-lockout-question-612479/)
JTR 96 TA Jun 11, 2008 01:10 PM
Ok, it's been so long since I've done the conversion I can't remember. . . Does the reverse lockout lockout when it has power, or when it doesn't? I.E. If I simply unplug the lockout selinoid, is it going to lock out reverse?
Thanks,
-Justin
BonzoHansen Jun 11, 2008 03:11 PM
Thanks,
-Justin
Yes. Power to disable.
Green96Z Jun 11, 2008 07:29 PM
As already said, the lockout solenoid is engaged with no power, with power it disengages. If you want to bypass it, you could always remove it and plug the hole in the tailhousing.
