Rear end question
Old Dec 28, 2005 | 12:09 PM
Redchevcam's Avatar
Rear end question
I have a 97 z28, not slp. I am trying to figure out the specs on my rear end. I want to put 3.73 in it but i dont know what it has now. I need to know what information i need to make the change and where i can find it.
Old Dec 28, 2005 | 01:02 PM
Capn Pete's Avatar
Re: Rear end question
A4 or M6. That would make it easier to figure out.
If you have an M6, then you have 3.42's (code GU6 on the driver's door jamb sticker). These are "3-series" gears, so you'd order 3-series 3.73's.
If you have an A4, you have either 2.73's (code GU2) or 3.23's (code GU5). 3.23's are also 3-series gears. However, 2.73's are on a 2-series carrier, so you'd have to order 3.73's for a 2-series carrier.
When you're ordering them, it's a GM 7-5/8" 10-bolt.
Old Dec 28, 2005 | 01:05 PM
2001NBMZ28's Avatar
First thing is check your RPO codes:
GU2 2.73 (A4)
GU5 3.23 (A4)
GU6 3.42 (M6)
If you think there's a possibility they may have already been changed or want to double-check use the calculator at www.f-body.org/gears/ When changing gears if you have TCS or not might make a difference too.
Edit: Capn your faster than I am.
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
