Rear End Gear Oil?
Old Mar 21, 2013 | 03:49 PM
dmaderaitt's Avatar
Question Rear End Gear Oil?
So I'm putting in my new transmission and going to change my rear end gear oil, so should I use regular Valvoline 80w-90w GL-5 with the Trans-X GM additive or LUCAS heavy duty 80w-90w that apparently does not require the additive since it is pre-mixed? Stock 10-bolt Rear with Stock 3.23posi-tract Gears, 172,xxx miles!
Old Mar 23, 2013 | 12:15 PM
Re: Rear End Gear Oil?
Generally speaking, there is no substitute for the genuine GM LSA. Most other LSAs don't seem work like it does.
Old Mar 25, 2013 | 03:35 PM
dmaderaitt's Avatar
Ok, thanks for the info, already went with the regular oil and the additive mentioned above, will get the GM additive next time if I have any problems, I have used it before but, not a GM product, same type rear end though.
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
