Rear end fluid leaks out when parked on a hill
I checked my rear diff fluid a few weeks ago and it was pretty low. I could not see any wetness on the axle, so I filled it up and kept an eye on it.
I drove the car for about a week not noticing any leaks. Then one day when it was parked on a hill it leaked out a puddle of gear oil. I jacked the car up and it looks like it was coming from the fill cap, the cover gasket and rear driveshaft seal looked dry. I checked the gear oil level and it was still full... So i thought maybe I overfilled it. I drove it for about another week not noticing any leakage, then last night I see another puddle under my diff, and my car is parked on the hill again... I Jacked it up again, it only looks like it coming from the fill cap and the oil level is still fine. Any thoughts/advice? __________________ |
Re: Rear end fluid leaks out when parked on a hill
I jacked the car up and it looks like it was coming from the fill cap, |
provide pic of 'fill cap' !
1 Attachment(s)
Attachment 13613
I filled the diff through the hole in the top where the vent cap sits. Was i supposed to fill it to the pipe plug on the side? If so then that means I overfilled it, probably by a lot. I did notice my rear diff was much quieter after filling it through the top. Would this hurt anything? Should i pull off the side plug and let it drain? Thanks. |
Yeah, it is only supposed to be at the level of the plug when it is out (on level surface). The plug is where you fill it.
