Rate my new tranny... 4speed auto
is this a setup worth 1300.00 plus a 12,000/12 month warr.? on a scale of 1-10.
High Energy Clutch Kit Molded pistons 1- extra foward clutch 1 extra 3-4 clutch 1 dual race sprag 1-2 hp accum valve, boost sleve and spring 1 hp 500 lift boost valve and spring 1 corvette servo 1 complete set of timkem bearings 1 2nd design input drum w/ hardened shaft 1 complete bushing kit 1 shift kit spacer plate 1 5 gear planatary 3500 stall your thoughts? |
Re: Rate my new tranny... 4speed auto
yes, it was worth that easily. i payed 1300 for mine and orignally the guy rebuilt it stock, it ended up with a cpt parts rebuild done by a local guy. no warranty other than come back and if he wants to... which luckily i decided to get on it within a month after i got it back and found it popped the rev limiter soon after.. so he fixed it.. 6 months later he got it right ;).. then wrecked it now its in paint... sorry for the rant but yeah you got your moneys worth and i think i did atm :p new radiator front bumper and paint job
High Energy Clutch Kit Molded pistons 1- extra foward clutch 1 extra 3-4 clutch 1 dual race sprag 1-2 hp accum valve, boost sleve and spring 1 hp 500 lift boost valve and spring 1 corvette servo 1 complete set of timkem bearings 1 2nd design input drum w/ hardened shaft 1 complete bushing kit 1 shift kit spacer plate 1 5 gear planatary 3500 stall your thoughts? its not only the parts that go into it , its also how its assembled. |
