question for M6'ers
question for M6'ers
what is the slowest you guys drive on the freeway in 6th gear? i live in oregon, commute through portland where traffic is routinely 55-60 especially through the 50mph zones of I-5. if i'm in 6th at that speed, rpm's are pretty low, like around 1200. car feels like it's lugging a bit, but will still accelerate (albeit slowly).
my question is this: am i hurthing anything by cruising the car at such low rpm's? i'd love to keep the gas mileage, but don't want to damage anything. i've heard extended driving at low rpm's will foul the plugs????
any input appreciated. thanks.
the owners manual says 6th gear at 50 if i remember correctly
down here in south florida, its flat as hell, so i'll do it at 45ish...but typically 50
on hills no way, or if you need ot speed up
Its it amazing how everyone here seems to follow the speed limit? ANd how curteous and slow they all are? And who's idea was it to make 26 as two lanes both ways?
When I'm on the flat parts of of the highway, I stay in 6th. If I'm going uphill or constantly changing my speed, I go back to 5th..
Now that I have 3.73's, I find myself ilngering in 6th a bit more confortably.
I don't think driving at low engine speeds will foul up our plugs anymore, thanks to sequential fuel injection for each cylinder, an the array of sensors feeding a powerful PCM thats driving it all.
yea, but if the engine isn't lugging, are you hurting it?
I think its like you only 50 hp to sustain 50 mph or so. Plus if you look in the manual, it tells that we all should be shifting at rediculously low speeds..
This is one of those argument of the ages... goes right up there with how often to change your oil and what shifter is the best..
do whatever you feel comforatble with.
Originally posted by robvas
I thought lugging your engine hurt it by the low rpm's causing low oil pressure and too much pressure on the bearing.
If you stay at 60mph, I don't think you're going to hurt anything.
If you have to go from 60 to 55 to 65 to keep up with traffic (IOW, the people in front of you can't maintain speed) then I think you'd be better off in 5th gear. Also, I think high load in too high a gear was part of the oil consumption problem (example: going 1/2+ throttle at 1500rpms in 6th gear); at least that's what GM said.
I usually go into 6th around 70mph and I'll stay in 6th unless I drop below 65mph or so...or like I said (Ken too), if I constantly have to speed up/slow down, then I'll drive in 5th.
I'll cruise at very low speeds/rpms too. As you said 1200 is about the limit before the oil pressure begins to drop. When i am cruising at low rpms like that i don't get on the gas. Just leave the throttle cracked and it pulls it, you can even pick up some speed using very little throttle, you don't have to stay up the other guys bumper
If you need to accelerate you can floor it and the motor does have the torque to pull it, BUT i downshift if i'm going to be anywhere close to 1/2 throttle at those rpms. I don't feel that i'm lugging it by driving at such low rpms since i use very little throttle.
-brent
If you need to accelerate you can floor it and the motor does have the torque to pull it, BUT i downshift if i'm going to be anywhere close to 1/2 throttle at those rpms. I don't feel that i'm lugging it by driving at such low rpms since i use very little throttle.-brent
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
