Programming for my Art Carr 4L60E
Im ordering the Art Carr 4L60E, the strongest one they build with a 3500 stall.
Now I ahve heard you are supposed to increase the shift pressure ramp with LT1 edit. I have already done this to correct for my 58MM throttle body. But I did not increase the MAX pressure amount any. Bascailly I made the PCM shift like it was at 50% throttle if I was only at 30% throttle. My question is, the Art Carr transmission increases shift pressure manually so should I leave my transmission pressure tables the same ? or back them off a little bit ? I dont want to have the wrong tune on this race transmission as its a daily driver and I want to make it last. :confused: |
whats the part # for that tranny? how much was it? they're in texas, right?
| All times are GMT -5. The time now is 05:19 AM. |
