CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   Problems pulling the trany (https://www.camaroz28.com/forums/drivetrain-44/problems-pulling-trany-375071/)
Red96Lt1 Jun 14, 2005 10:34 AM
It's almost all of the way off of the splines and the bellhousing is hitting the firewall. I've tried jacking up the front of the motor a little, didn't help too much. Any suggestions? Thanks.
madwolf Jun 14, 2005 10:42 AM
Re: Problems pulling the trany
Did you try lowering the jack (so that it lowers the tranny and it sits at an angle)? Mine had lots of room and that's with new polyurethane motor mounts.
rngilliland Jun 14, 2005 12:37 PM
It sounds like you are taking the trans and bellhousing out together. If so you need to remove the trans from the bellhousing and take the trans out first.
Red96Lt1 Jun 15, 2005 01:52 PM
Yeah, I was pulling it with the bellhousing. Ion, did you pull it with the bellhousing?
madwolf Jun 15, 2005 06:05 PM
Nope, I did it without the bellhousing. That's the way to do it. Same goes for the install.
