Pinion seal ALWAYS leaks!
I dont know what the deal is but Ill replace it and within a few months it will drip again. The only thing I can think of is my DS is out of balance ruining the seal but I dunno. On the highway around 70-80 I get this horrible pulsating drone from under my car... does taht sound like DS to anybody else?
Re: Pinion seal ALWAYS leaks!
Originally Posted by Cmr0z28
Do you have a poly tranny mount? My poly caused terrible droning above 70-75mph.
check for a groove in the yoke, if there is a small groove you can use a sleeve kit from napa or car quest
if the rear is making some noise your pinion bearings are probly bad,
the seal can be installed without re-setting up the whole rear end if your carefull
the correct procedure for a new pinion seal involves removing the pinion, checking the bearings and using a new crush washer to set the pinion pre-load
I had the groove in the pinion yoke. GM has a kit that replaces yoke with new one and comes with an improved seal. It's about a $100. Worked great. I know DTS carries pinion yokes a little bit cheaper than GM but they had to order it and I was too impatient.
Noct
Jul 14, 2015 01:18 AM
camaro02DK
Jul 5, 2015 09:24 AM
kev93z28
Aug 19, 2002 12:48 AM
