master install kit..
Old Oct 21, 2004 | 07:54 PM
Friscoz28's Avatar
From: looking at thick girls in san francisco in my camaro
im buying 3.73 for my 2002 z, and i just wanted to know what is the master install kit.
Old Oct 22, 2004 | 12:14 PM
PAGregSS's Avatar
Re: master install kit..
Generally the master install kit will contain the following:
1. Pinion nut
2. Front and rear pinion bearings
3. Carrier bearings
4. Crush sleeve
5. Ring gear bolts
6. Carrier shims
7. Pinion shims
8. Marking compound
I believe that's it off of the top of my head. The difference between the basic and master kit is the bearings. If you go with what some call the deluxe kit, you also get wheel bearings and axle seals.
Nov 18, 2023 07:21 PM
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
wytblur
Mar 2, 2003 03:40 PM
wytblur
Aug 5, 2002 02:10 PM
