Line lock
Old May 4, 2006 | 08:50 AM
Honda Hunter's Avatar
Line lock
Why cant a line lock be used like a trans brake? I know it sounds like a dumb question but inlighten me.
Old May 4, 2006 | 09:43 AM
97FormulaWS-6's Avatar
Re: Line lock
What do mean used like?
Old May 4, 2006 | 09:45 AM
Re: Line lock
I mean can you use the line lock off the line at the dragstrip rather than holding your foot on the brake to take off?
Old May 4, 2006 | 09:51 AM
JakeRobb's Avatar
Super Moderator
Re: Line lock
You can do that. It's better than using the pedal, because the rear brakes aren't engaged so you're not wearing them out.
Old May 4, 2006 | 09:53 AM
Re: Line lock
Would it hold stronger than you could with your foot?
Old May 4, 2006 | 10:40 AM
JakeRobb's Avatar
Super Moderator
Re: Line lock
No. You push the pedal down as hard as you can and then engage the line lock -- it holds it right there until you release it. So in effect, it is exactly as strong as your foot.
Old May 4, 2006 | 10:42 AM
Re: Line lock
Gotcha. Thanks
Old May 4, 2006 | 10:24 PM
Loadre's Avatar
Re: Line lock
Line locks suck for leaving off the line. Foot braking is a better way to go. With the line lock, if you have sticky tires on the back at all it will push right through the brakes. Foot braking you have pressure on the back calipers helping to keep them still. Without this you can start turning the tires over pretty easy.
Old May 5, 2006 | 07:37 AM
Re: Line lock
OK, but how do you foot-brake with a M6 car where line-locks are most prevelent?
Is your 3rd leg that big and powerful where you can use it to hold the brake while your 2 real feet operate the gas and feather the clutch?
Old May 5, 2006 | 07:42 AM
Loadre's Avatar
Re: Line lock
haha That reply was based around the fact that he has an A4.
...and lets leave my 3rd member out of this.
JakeRobb's Avatar
Super Moderator
Re: Line lock
Line locks suck for leaving off the line in an A4.
But you have an M6, so get a line lock.
Old May 5, 2006 | 09:10 AM
TQdrivenws6's Avatar
Re: Line lock
First yellow:
Right foot: Heel on the brake pedal, toe on the gas.
Left foot: On the clutch
Last yellow:
Right foot: Slip right foot off of the brake and put your foot through the floor.
Left foot: Side step.
Green:
Hang on and hope your drivetrain can handle it.
Old May 5, 2006 | 10:14 AM
kick Z tail out's Avatar
Re: Line lock
Except you'll have less resistance to the forward motion and (if applying the same throttle as before) you may push right through the beams.
But yeah, line locks are commonly used by M6 drivers to keep them from rolling. But you won't be able to use them with an A4 car as if they were a transbrake.
Old May 5, 2006 | 10:17 AM
JakeRobb's Avatar
Super Moderator
Re: Line lock
You could get two line lock kits and install one on the rear brakes, and then wire in a custom switch so that you could lock just the fronts or all four. There'd be some custom work involved, but I don't think it would be too bad.
Then you wouldn't lose any braking power over a footbrake, and you'd still save on rear brake wear in the burnout box.
Just a thought.
Fastbird93
Apr 9, 2016 07:01 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Jlo
Jun 24, 2015 11:54 AM
Pampered-Z
Apr 14, 2015 05:38 PM
