CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   Hurst or B&M??? (https://www.camaroz28.com/forums/drivetrain-44/hurst-b-m-296977/)
LPE_wannabe Aug 31, 2004 11:20 AM
Hurst or B&M???
when i say hurst i mean factory hurst...which shifter is better and why...any other names i should look at??? thanks
irishz28 Aug 31, 2004 02:58 PM
Re: Hurst or B&M???
i have had 3 diffrent shifters in my z, and i would have to say out of all three the factory hurst is the best. the pro 5-0 is alittle rough going through the gears, and so is the b&m. the b&m is not as bad as the 5-0. they are good to slam the $hit out of, but for daily driving go with the factory hurst and a lous short stick, its smooth and you can still slam it. if you miss a shift with that setup you should be shot.
LPE_wannabe Aug 31, 2004 04:14 PM
Re: Hurst or B&M???
cool...sounds good to me...i'll be doing that then...thanks
