how many qaurts to fill a t56??
Old May 9, 2007 | 12:37 AM
ZX636RIDER03's Avatar
just a quick question for anyone who might know. How many qaurts are needed to fill up my 6 speed transmissions. i ordered 4 qaurts of royal purple dextron III atf. will that due??
Old May 9, 2007 | 12:52 AM
bingo's Avatar
4 is all I have ever used.
Old May 9, 2007 | 02:39 AM
Ratlor's Avatar
I bought 4, spilled at least half on the ground when the pump I was using gave out, and still had enough to make the fluid go out of the fill hole. So 4 should be good.
Edit: That is a beautiful SS, by the way.
Old May 9, 2007 | 06:23 AM
METALBEAST's Avatar
The T56 Service manual on Shoebox's site says 4.1 quarts.
Old May 9, 2007 | 09:08 AM
Dave1980's Avatar
Add through the shifter hole, less messy. (4 quarts)
Old May 9, 2007 | 04:18 PM
thanks.. that was going to be my next question i usually fill it through the shifter hole cause your right its not as messy, maybe i should by a new hurst shifter while im at it??? well thanks everyone for the info
Old May 9, 2007 | 04:49 PM
seawolf06's Avatar
You can add through the shifter, but it's hard to tell if you're adding the right about. It's hard to drain all of the old fluid out. If you do fill through the shifter, take out the fill plug so that it won't overfill.
Old May 10, 2007 | 11:18 AM
Dave1980's Avatar
True.... I drained my tranny when the car was jacked up pretty high from the front. Being the drain plug is low near the rear of the T56, I figured this would be good. I think the main thing to focus on when your filling, is that if your going to use the fill hole as a measure to see how much fluid is in the tranny, that you make sure the car is level.
Old May 10, 2007 | 01:20 PM
seawolf06's Avatar
Very good point, Dave. Don't do it when it's too cold or too hot, as that might also change the volume of the fluid.
Bxlt1
Sep 29, 2015 03:18 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Pwilson59
Sep 3, 2015 08:47 PM
1slow93z28
Sep 1, 2015 06:22 PM
