Hot trans
I was drag racing last night and did about 7-8 passes. My tranny was around 220-230* Also I later found out i was about a quart low of tranny fluid. Would the excess heat be caused from low fluid? Also my last run at around 80mph my motor surged to 5800 I was in third(auto) would the low fluid do that also?
ps: It was about 80* at the track, 6pm |
Re: Hot trans
Originally posted by 1msfyter I was drag racing last night and did about 7-8 passes. My tranny was around 220-230* Also I later found out i was about a quart low of tranny fluid. Would the excess heat be caused from low fluid? Also my last run at around 80mph my motor surged to 5800 I was in third(auto) would the low fluid do that also? ps: It was about 80* at the track, 6pm EDIT: if u haven't already, get urself a tranny cooler and lower your fan settings to get some more air moving through the cooler. a deep trans pan will also help. i have all of the above and run around 160* in extended driving with a high stall converter. |
